Reassign a sketch to a new datum plane
Hello everyone!
I'm reworking a part in an assembly. Due to changes in the design, the former part that the sketch was linked to does no longer exist. Now I have a sketch that tells me that it's "Parent of the plane has been supressed or modeled away" which makes sense, since the part is no longer there. However I would like to keep this sketch, as many other features down the line depend on it's geometry, and remodeling the sketch will probably break all these parts. Is there a way to assign a new datum plane to this sketch? Hopefully without breaking anything down the line.
Cheers!
Re: Reassign a sketch to a new datum plane
Hi @Felix_Hilken,
Check "Replace with Independent Sketch" if it can be useful in your case.
Also did you try to edit and reattach sketch?
Ganesh Kadole
Hi @Felix_Hilken
Edit the sketch and use reattach command to specify a new plane to place the sketch.
