Recommendation for a GUI based SHA512 checksum utility.
Can anyone recommend a good, GUI checksum utility that is safe and can check SHA512 checksums?
NX 12.0.2
Re: Recommendation for a GUI based SHA512 checksum utility.
If you have 7-zip installed then you can download WinCryptHashers.
http://www.tc4shell.com/en/7zip/wincrypthashers/
Install instructions in the zip-file.
/Mattias
/Mattias
NX5 -> NX(1847)
I-Deas Master Series 4 -> NX I-Deas 6.4
