Recover Link between 2D and 3D drawing - NX 10
Hello!
Please, if someone can help me, I would be grateful.
I have changed the name of my 3D component, and when I have opened the 2D drawing of the same component, the link has been lose. How can I correct this problem, without have to draw again ?
Thanks.
I am Brazilian and I am talking from São Paulo.
Re: Recover Link between 2D and 3D drawing - NX 10
MB3 on component, then replace component, and choose from browse the new name part you have assigned.
Ciao
@GiovaniLuiz You should not rename the part file names at the OS level as it will break the links that you know already.
While replacing the component with renamed one, make sure that 'Maintain Relationships' option is toggled on so that attributes,constraints will be maintained after replacing the component.
FYI, You can also use 'Editing Existing Assembly' to replace the components from the assembly.
Menu > Assemblies > Cloning > Editing Existing Assembly.
Ganesh
