Rectangular detail view
with NX11.0.1 I've see some enhancement on detail setting, but like the image attached I'm not able to obtain. Exist e setting or I need to insert en ER ?
Thank you...
Using NX1859
RuleDesigner PDM
4 REPLIES 4
Re: Rectangular detail view
I got it work using the type of Rectangle by corners and label on boundary in the settings.
Picture1.pngDetail Menu
And here is my output.
Scott
Scott
Sorry Scott,
but the detail view rectangle is present because you have the option 'show border view' enabled'.
Thank you...
Using NX1859
RuleDesigner PDM
Existing ER 6304789. If you want a border in the view, expand into the detail view and create a rectangle. Then expand back out of the view, edit the boundary of the view and select "Break Line / Detail" and select the rectangle.
Regards, Ben
How do you make NX10 Auto generate a Label for a boundry detail?
