Redundant dimension out of the sheet and not able to delete
Hello All,
While editing the drawing sheets in NX12, came across one redundant dimension which is stretched outside the sheet and not able to move inside and not even getting deleted.
If anyone faced this kind of issue, please let me know how it got solved rather than deleting the view and re-dimensioning.
Thanks in advance.
Ravi
Re: Redundant dimension out of the sheet and not able to delete
Hi @Ravi369 ,
Run part cleanup then try again.
Hi @GaneshKadole ,
Part cleanup has been done and raised the issue to concerned IT department here and finally deleted the view followed by re-dimensioning as it is very minor with 4 dimensions in that view.
I just wanted to know if this kind of problem come in future and the way to solve it without deleting the view.
