Reference Sets, and use of JT's in Visualization on Teamcenter
Hi
we are heavily into Reference Sets here for defining what we see in an assembly in terms of Datums, Sketches, and more importantly parts that have been deformed (springs, Washers, Flexible PCB’s, etc). We have been using NX/UG for 25 years hence how we work.
Moving forward we want to use Teamcenter for viewing JT assemblies, but owing to the way they are constructed (JT’s)i.e. from TC BOM, the Reference sets cause us an issue as all of the data gets dragged in. So our Teamcenter generated JTs can contain multiple representations of our models, Flat, Formed, Long, short, etc.
Has anyone else come accross similar issues, and how did they resolve?
Is it:
Reference Sets
AltReps
Deformable parts
or something else
Also what about our legacy data? How can we correct?
Martyn, Snr CAE Engineer, Renishaw PLC
NX10 Tc10
Re: Reference Sets, and use of JT's in Visualization on Teamcenter
Is anyone actually using Visualization in teamcenter to view JT assemblies?
NX10 Tc10
If you send the assembly to Vis then you can RMB on the assembly and use Replace Reference Set. I presume you have your tessUG.config file set up to export all reference sets.
We use Vis Mock-up but don't use multiple reference sets.
Mike
NX 12.0.0 TC11.3 VMU 11.3
