Relation between reference sets and measure bodies function..
I am wondering exactly what the process that NX uses to Measure Bodies, and how does the reference set of a part play a role in this? I only ask because, from my limited understanding of NX, the Measure Bodies function looks at each parts refernce set before measuring it. If this is true, then this could present some issues based on certain design practices.
Is it possible to Measue Bodies without having to look at the reference set?
If I am wrong please correct me.
Re: Relation between reference sets and measure bodies function..
When you use the "measure bodies" command, you can use a selection rule to select a single body, feature bodies, or the bodies in a group. Reference sets don't play a part in the "measure bodies" command.
