Remove material
Ciao,
how remove material from a body assigned by the command assign material?
Thanks in advance
Cesare
Re: Remove material
Please try this. Hope it helps.
Best Regards
Kapil
Re: Remove material
Run File, Utliities, Part Cleanup.  check the "delete all materisls" box in the bottom section.
-Dave
Re: Remove material
Thanks to kapilsharma that solved the problem; to Davek: thank you as you taught me something new!
Cesare
Re: Remove material
(Instructions for ST7)
In Pathfinder, right-click on the Material Node, and click Remove Material
