Rendering using all workstation in the lan
some CAD or rendering software like Keyshot can utilize workstations in the lan to partecipate at the render.
NX can do this without to use an NVIDIA Visual Computing Appliance or VCA machine as the Ray Traced Studio remote rendering server ?
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
Re: Rendering using all workstation in the lan
Hi @cubalibre00,
Yes.  With NX Iray Ray Traced Studio Remote Render you can connect to a remote workstation or cluster of workstations as well as to a high-end Visual Computing Appliance (VCA).
The remote workstation needs to be configured to support Iray rendering and it will need to have NVIDIA Iray Server installed and running on it in order to access it from your "client" workstation or laptop running NX with Ray Traced Studio.
The controls for Ray Traced Studio Remote Rendering can be found in the Ray Traced Studio Editor -
HTH,
Patti
Patti Longwinter | NX Product Manager
Visualization
Digital Factory Division
Siemens PLM Software Inc.
