Reorder list for Assembly Constraints dialog box?
Is there a way to reorder the list in this dialog box for Assembly Constraints?  Having Align/Lock way down the list is annoying; it is even more annoying that it is not in with the Touch Align constraint as a toggle.
1 REPLY 1
Re: Reorder list for Assembly Constraints dialog box?
It doesn't look like you can reorder the list. What about using "Show Shortcuts" at the bottom of the pull down list of constraints? That way you get the constraint types as icons on the dialog, rather than pulling down the list each time. BTW, it appears that NX11 has replaced the pull down with a palette of icons, rather than shortcuts.
Ben
