Replace Sketch Entity
Hello to all,
My name is Danijel,
I work as a designer in R&D center of one company.
I have over 12 years of experience in CAD design, using software such as SolidWorks and Inventor.
Company bought licences for NX11 Mach3 so I have oportunity to learn NX from the beginning.
This forum is awesome and I am sure I will spent a lot of time in reading of interesting topics.
As title of this topic says, I am wondering if it is possible to replace sketch entities (one entity with another).
I have searched over the forum to find a similar topic but I didn't have a luck.
Here is what I meant:
https://www.youtube.com/watch?v=-TRGReFUp88
Any help is very appreciated.
Danijel
Re: Replace Sketch Entity
Dear Danijel,
We have a replace feature. here it is possible to swap to feature (example two sketch features  with eachtother)
Right mouse button on the feature you want to replace and then use the "replace" feature
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Siemens Legend Siemens Legend
Siemens Legend
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
To replace an entity in a sketch, just activate the sketch, create the new curve and delete to old one if applicable. You can add/remove multiple curves, change the profile completely you have a lot of control. This movie shows a simple case of replacing a line with an arc.
ruud_vandenbrand wrote:
Dear Danijel,
Dear Ruud,
I didn't know that you can easily replace features by other features. That's great!
Reason why I have created this topic is explained on the attached video. I have many features which are dependent on the face(s) created by other features.
How to avoid breaking of the new features because of loosing referent face(s) from some other features?
(view in My Videos)
Danijel
Hi bevyboy,
I have tested what you said and it works fine, but what I meant while I was creating this topic is explained on the video  that I have attached in my previous reply.
Please take a look.
Thank you!
Danijel
Hi @danijelVR,
I’m a CSWE and I find NX’s Replace command is quite powerful.
When you use it please make special attention to “Original Parent” and use the arrow at the bottom to find potential downstream issues and to fix them.
If a feature is driven by Basic Curves/Dumb Curves (Not available in Solidworks) then edit the feature and de-select the old (Deselect button is quite useful). Then check the Selection Scope & Curve Rule pulldown and select proper selection (e.g. Connected Curves, Tangent Curves…) and pick the new curve. After that you might get “Map Parent” window where you could specify path directions of old to new which will eliminate most of the child feature issues.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
NX is working with edge and face id's
when you change the line like in your movie the extrude creates a new face.
this will give the face also a new ID. (for example from ID 3685 to ID 4145)
the second extrude was extend until ID 3685 but when changing the line that ID isn't existing anymore.
i need to test how you can do this the best way to avoid this problem.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Siemens Legend
As discussed above if you use map parent that should make all the downstream features update
mike_fdo wrote:
Hi @danijelVR,
Hi Mike,
I am pretty new with NX so it is little bit difficult for me to easy find options that you mentioned.
I will follow your instructions to figure out what you suggested. It will be great if I would have a video example (as bevyboy provided) cause it is better for understanding.
Thank you very much!
Danijel
Ruud,
Any help is very appreciated!
Danijel
