Results not loaded in simulation
I prepared simulation  in NX. When I try  open results it gets an error:
in attachment I also add raport from simulation. Do you have any Idea what could went wrong?
Best regards
lukipap
Re: Results not loaded in simulation
Hello @lukipap,
Log file looks good. But the message on the wrong format, could also simply mean the op2 file is not created.
Do you have the f06 file? Or diag file? Can you post this here?
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
