Reusable Object Library
How can I create a reusable object like the ones Siemens Nx brings in the library that when I insert it, the pocket creates me. How the screws,bolt do and that is associated with a Krx table.Thank you
Re: Reusable Object Library
ramarc --
Check out this section of the NX docs:
Workflow to define and use a reusable object
Using object attributes will be the key to getting the automatic pocketing behaviors.  (In particular, "REUSE_SUBTRACT" for a pocket.)
Reusable object attributes
Screws, bolts, etc. in the Reuse Library are normally managed with Part Families and then packaged as a "Knowledge Enabled Component" (a.k.a. Reusable Component).
Knowledge enabled components
Hope that helps!  :-)
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Tel: +1 (602) 441-0683
taylor.anderson@siemens.com
