Reuse Libary Problem
Help me please?
Unable to play video. Please try again later.
(view in My Videos)
Re: Reuse Libary Problem
Unfortunately your video does not play for me. I'll assume it's happening after you dragged a standard part from your Reuse Library into your assembly. Which version of NX10 are you using? I found a couple of similar issues reported against NX10 base, which were corrected in newer maintenance releases. The current MR is NX10.0.3.
If you have the current release already installed, please consider reporting this problem to your local GTAC office: http://www.plm.automation.siemens.com/en_us/support/gtac/gtac-hours.shtml
Regards, Ben
Look at the name manager on the clone options, maybe you have an incorrect auto number.
