Reuse Library - Clone
Hi there,
I've created a reusable item in Teamcenter. So when I've reused it with clone option and defined their dimensions the NX just "Save As" using original file and it losted my choice.
I attached a picture that explain how I setup the item. I prefered to used that because Family of Parts doesn't create drawing automatically and doesn't permit to change manually the expressions on insert.
15 REPLIES 15
Re: Reuse Library - Clone
Hi @bauler,
Does the following solution help?
Reuse Library | Clone instead of reference
Regards, Ben
Hi @BenBroad!
Thanks again!
Let me show you what happened. I attached two videos that explain better.
1 - REUSABLE_WITH_DRAWING.avi - Reusable item that contains drawing (I've using Master Part concept)
2 - REUSABLE_WITHOUT_DRAWING.avi
I just tested NX12.0.0 with Tc11.4 and the size did not reset at any time during the operation.  Is this repeatable for you with all reuse components that have drawings?
(view in My Videos)
Regards, Ben
Yes! this happened all times that item contain drawing.
Could you send me your procedure to create a Reusable item?
(view in My Videos)
I will test on NX 11.0.2 and report back.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
@BenBroad
I tested in NX 11.0.2 and works fine.
I've been using TC 11.4, I believe it is a bug.
Which version of NX 12 were you using? I could not reproduce using NX 12.0.0 and Tc11.4.
Ben
NX 12.0.1 | TC 11.4
