Re: Reuse Library - Clone
Hi Bauler,
Yes, I can confirm that this looks to be an issue with NX 12.0.1. Please open an IR with your local GTAC office and report this problem (refer to this forum thread).
Thanks, Ben
@BenBroad when you reuse a reusable part that contains drawing does Teamcenter clone only 3D and 2D datasets? For me the Teamcenter does clone excel and krx together.
Everything was cloned - UGMASTER, UGPART, MS ExcelX and KRX datasets.
Regards, Ben
When the reusable part doesn't contains drawigs the Teamcenter doens't clone Excel and KRX datasets. So if I don't want to clone that will I change relationship type from iman_specification to other type?
This looks like a bug to me.  I also confirmed that the KRX and MS ExcelX datasets are not copied over if the Item Revision does not contain a UGPART dataset.
Can you open an IR with GTAC and have them review the issue?
Thanks, Ben
Off course.
