12-05-2017 06:15 AM
Good morning.
I have a question about the NX reverse engineering software.
We did know about a NX8 part named Imageware.
What was its purpose?
It's still used with NX11 - 12, or now must use an other software?
Thanks!
Best regards,
Beppino
Solved! Go to Solution.
12-05-2017 07:33 AM
Beppino, the commands to perform reverse engineering are in NX 11 and NX 12 now. In addition with the introduction of Convergent Modeling(TM) Technology, depending on what you need to due, many things can be accomplished using the faceted body without having to perform many of the traditional reverse engineering tasks.
Scott
12-05-2017 07:40 AM
Thank you for the your answer.
I will check the NX reverse engineering part.
Beppino
