Revolve, Until Selected
I want to use Revolve to "sweep" an arc along another arc, but find that Unitil Selected in Rovolve accepts only "Face, Body, Datum Plane".
Is there any efficient way to do the job without creating an extra object at both ends of the guiding arc?
Thanks!
Re: Revolve, Until Selected
 you can use the expressions i the sketch to controle your revolve.
revolve.PNGin this case you may need to use the - for one of the 2 expressions
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi @ruud_vandenbrand   Thank you for your suggestion of using expressions!
