Router error. Failed to get directory from filename NX 9
Hi (assembly.prt not opening)
When opening .prt assembly:
Router Error.
xxxxx.prt - Failed to get directory from filename.
and the assembly won't open ?
NX 9
3 REPLIES 3
Re: Router error. Failed to get directory from filename NX 9
Have you checked the syslog left by the router?
Mark Rief
Retired Siemens
You entered "xxxxx.prt" for the filename. Does it contain any special characters like é, ï, ß, ì etc?
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
Looks like it demanded the whole file path...to be pasted
I first copied and pasted to my desktop a folder containing the assembly:
like from C:\ Data\ 3DFiles\ Unit\ Assemblyfiles\ Assembly.prt
to my "Desktop"\ Assemblyfiles\ Assembly.prt
and it didn't work and gave the error.
Then I copied and pasted the full path:
"Desktop"\ Data\ 3DFiles\ Unit\ Assemblyfiles\ Assembly.prt
and it worked :-)
