Routing: Twisting an oval cable
Hi guys!
I have very little experience with electrical routing so I thought I'd ask the experts here...
Is there a way to twist an oval shaped cable on a spline path so that it's for example 0 degrees at the beginning and 90 at the end?
Using NX11...
Appreciate the help!
3 REPLIES 3
Re: Routing: Twisting an oval cable
Hi @hajnal,
Routing does have a Stock Twist command, however, it's restricted to rectangular stock only.
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
Thanks Ben. If such a function is available for rectangular shapes, will it also be available for other shapes with newer releases of NX? Does such an enhancement request already exist?
Hi @hajnal,
I had a look through our existing ER's and didn't see any requesting that non-rectangular stock profiles be allowed for the twist command.  Please open a new IR with GTAC and have them submit an ER on your behalf.
Regards, Ben
