Routing: Unable to load application view
Hi Reader,
The Mechanical routing is failing to run and throwing the below error.
Error:
Please let me know how we can address this issue.
Raghavendra
Sr. Software Engineer
Tech Mahindra
Re: Routing: Unable to load application view
I don't find the syslog in the path
D:\Users\...1\AppData\Local\Temp\....syslog
Hello @Raghu,
When you are in the NX session and this error comes up, go to File --> Help --> Log file. Now you can save the syslog from here. or just look in the syslog yourself for clues that might explain what is causing this.
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Hi. I have the same problem.
Routing app will not load in TC-mode. Works in Native mode.
Anyone have a suggestion?
Your log file shows that you have:
UGII_ROUTE_UGMANAGER_MODE=TRUE
NX is looking for routing administration files in Teamcenter - i.e., it is looking for an item in Teamcenter that contains the application view file (ugroute_mech_metric.xml). However, your setup is currently pointing to an application view file on your OS.
Your solution is either set UGII_ROUTE_UGMANAGER_MODE=FALSE, or import your routing administration files into Teamcenter per the documentation.
Regards, Ben
That did the trick. Thanks for the help !
Had set  UGII_ROUTE_UGMANAGER_MODE=FALSE in
NX90.bat
NX90library\NX90env_routing.dat
but Tc_NX90TCIN.bat was still set to TRUE
