Routing electrical for control panels
Hello, Are there any recommendations or tips for using the "routing electrical" for use with control panels?  I'm more familiar with using routing systems for wiring harnesses, but not for routing wires in a control panel.  Any recommendations or links to resources would be appreciated.  Thanks
Re: Routing electrical for control panels
The routing path creation process  remain the same. You have some additional tools like cableways layout calculation. The bundle diameter is also automatically calculated.
If there is anything you are looking for specifically in cabling let us know.
To me the overall process deviation is not that much.
Kapil
