SECTION-COMPONENT attibute in Reuse Library
Hello guys,
in my company we do not use standard components except in a department.
I am unfamiliar with the reuse libraries I know they use part family.
My collegue want to make sectionable a part of the reuse library in which the 'SECTION-COMPONENT' attribute is set to NO.
The command 'Section in View' do not seem to work.
Thanks for your help.
Cesare
Re: SECTION-COMPONENT attibute in Reuse Library
Sorry if i have misunderstood your query.Do you mean this?
(view in My Videos)
Best Regards
Kapil
(view in My Videos)
While creating the section view, delete the components from the 'Non-Sectioned' area under the settings
or it can also be deleted from the base view/projected view dialog.
In 'Section in View' dialog, 'Make Sectioned' option should be toggled on to create the section of the components having attribute 'SECTION-COMPONENT' with NO value. sectioncomp2.PNG
Ganesh
Thanks to everyone for the appreciated answers.
Ciao
