STEP 214 conversion error in NX 10.
When i am exporting a model in to STEP214 in NX10, i am getting error (Pls see the attached screenshot for ref.)
Please help..
Vinay
5 REPLIES 5
Re: STEP 214 conversion error in NX 10.
Most of the NX license bundles include STEP AP203/214.
Is this for native NX or managed NX?
Did you check it on another machine?
Ganesh Kadole
like @GaneshKadole is telling check your license file
open your license file in Notepad and check for the following increment
  • step_ap203
  • step_ap214
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hello Ganesh,
Does Step Export work in NX managed mode?
I noticed that there is no option to export STEP when NX is opened in TC managed mode.
@TauseefAkhtar
Yes.
Are you sure about it? Check the same with command finder. The command will not be available if respective text is removed or commented out in the menu file.
Ganesh Kadole
Found it. Thanks a lot Smiley Happy
I searched it and could find the command. Not sure, it said command is hidden. Now I am able to see it.
