Save Assembly as Part
I'm looking for a reliable way to create a Part from an Assembly.
For context: Many downloaded vendor files come into NX as assemblies, sometimes with many parts. To avoid keeping copies of all these part files it is most convenient to convert each of the parts into a "dumb solid" within a single part file.
I've found that with some of these assemblies I can export to an IGES or STEP file, then import that file to get this result. Often though, the resulting file either retains each part as a separate file, or the entire assembly is nothing but "dumb" surface bodies.
Has anyone discovered a method to reliably convert assemblies into parts made up of solids?
7 REPLIES 7
Re: Save Assembly as Part
What about "Simplify Assembly" cmd?? It makes one solid body from an assembly..
3pc assembly can look like this after it:
and you can even delet parts from tree:
Thanks for the tip; it might be the answer for some, but it requires an "Advanced Assembly Modeling" license, which I don't have. (Solidworks Standard does this very easily, btw: File, Save As, Part.)
In the meantime though, I've found another way. Will post a reply to my original question.
Found my own answer:
In the Assembly, make one component the Work Part, then from the Menu use Insert; Associative Copy; WAVE Geometry Linker (Copies geometry from other parts in the assembly into the Work Part.)
Under Settings, uncheck "Associative," to avoid external references in the resulting part, then select only those components that are needed to represent the original Assembly in the final Part.
you can set the option "Flatten Assembly" in the step- import option.
then you will have a single part and not an assembly
Aha! Should have tried that; I thought it would just make the assembly one-level deep.
Filter => Face
Select all
Copy
Create new part
Past
HEIA-FR, O.Mauron
Appreciate the advice, but I think cadmin had the better solution above. I doubt the method you recommend would produce solid bodies, which I always prefer.
