Save big JT assy as NX parts
I have a big JT assembly with nearly 10000 jt´s and I need to convert them into NX parts in order to do some work.
The problem is that my workstation runs out of memory (I have 32 gb) and that NX (10) always want to extract the exact data which then results in a memory shortage.
I switched of the extract exact data option in the customer defaults but it seems NX still extracts the solids.
Does anybody have an idea how to prevent the extraction or another way to translate the files into NX?
Thanks.
Klaus
7 REPLIES 7
Re: Save big JT assy as NX parts
If you wish to convert the JT's into NX part files, what sort of data representation were you expecting if it wasn't a solid?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
The files should be in a good enough quality for a clash and clearance and an extraction path analysis.
We wanted to use NX10 since it has a new algorithm for the extraction path and is now much faster.
But it seems we have to use Vismockup.
I`m just kind of disappointed that NX cannot handle big JT assemblies properly.
Did you try bringing them in as 'lightweight' faceted models?  They will work with the extraction path software.
Irvine, CA
Submitted content: I`m not quite sure what you mean with "bring them in".
I simply opened the JT assembly in NX and then Save (or at least tried to) the assembly to create part files.
Could you explain what you mean and how it can be done instead?
Have you talked to anyone in GTAC about this?  Opening JT assemblies as an Assembly in NX is not always as easy as it should be.
Irvine, CA
It`s quite a big JT assembly but I will open a call and upload the assembly.
Hopefully there will be at least a final statement how NX really works with JT assemblies.
My incident report was converted into a serious problem report.
let´s see how this turns out...
