Saving the Family Report of a .prt File
Hello Everybody,
I want to save the .prt File ánd the family report shell also be saved in the same direction automatically.
Is it possible?
Kind Regards,
Rene
9 REPLIES 9
Re: Saving the Family Report of a .prt File
Hi @Rene_99,
Can you explain what you mean by 'family report shell"?
This is not NX terminology that I am familiar with.
Thanks, Ben
Hi Ben,
Thank's for the quick response!
I've added a PDF below.
Thank you!
Hi @Rene_99,
In 'Info' column of assembly navigator, components which are part family members will show symbol as shown in the image. You can export the information to browser or spreadsheet if needed.
Ganesh Kadole
Thank you for your good response!!
I will try write a makro which saves this assembly Informations.
Is the family report not showing a information dialog?
So far I know it should give a dialog with the report in it.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi ruud,
That sound's interesting.
How can i save this file?
Greets,
Rene
@Rene_99 wrote:
Hi ruud,
Greets,
Rene
Menu > Information > Assemblies > Family Report
It will report the information about the each component in the assembly for the part family member criteria.
Ganesh Kadole
As ganesh shows.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Okay,
Thank you!
Kind Regards,
Rene
