Saving the results of EXAMINE GEOMETRY
Hello Experts,
Is there a way to save the results of examine geometry?
It will help while fixing the model / imported data manually.
As of now, after fixing some surfaces, I need to run the examine geometry to find the next surfaces which need fixing.
Thanks in advance.
Re: Saving the results of EXAMINE GEOMETRY
For such requirements HD3D (Checkmate) will come in quite handy as you can run Examine Geometry checks from there also (and a lot more than that) ...as you fix some issues...you just need to refresh the results for figuring out the rest.
Best Regards
Kapil
Thanks a lot Kapil
