Scale curve along with Body
I'm Using NX-9.
I want scale Body and Edges of profile of the body at the same time. But i found scale body option only.
How can i scale the curve.?
Please, say me the procedure to scale the curve.
Re: Scale curve along with Body
Using Edit > Transform > Scale, you can scale the curve.
I am assuming that you want to scale a curve and feature body (solid/sheet) that is created using the same curve. Find the attached video.
Ganesh
In NX 11 the Scale Curve command works the same as the Curve Body command. You can create one then on creating the other link the scale expression.
Steve V
