Scaling components in NX 8.5
Hi!
I need to scale down imported part files of igs, step or solidworks format on NX 8.5 software. How can I do this?
Re: Scaling components in NX 8.5
Siemens Genius Siemens Genius
Siemens Genius
Hi
you have to use the Scale Body command ( Tools / Insert / Offset-Scale / Scale Body)
If you have an assembly and you want to scale all components, you have to use this command on each individual component ( make each component the work part) and scale them using the same scale factor and the same origin ( 0,0,0) for example.
Hope this help
