Scientific Threads
I'm modelling a part right now that uses scientific thread sizes. The tool in particular is a 1/4-36. I cant find that particular threaded hole in the lists, even under the Ultra Fine standard.
So either A) Is there a I can add a custom threaded hole in the hole dialog box or B) is there a way I can create a new "scientific" standard that I can add these threads to so I can work with them in the future.
Thanks.
Re: Scientific Threads
If you look in the Help Documentation and search for 'thread lookup tables' you will find the instructions on creating your own thread specs.
Alright thank you
