Searching small .jpg picture in big draft
Hi everyone,
I have problem, because I have problems with finding small jpg on big draft. I realize that there were some jpg after I print it. There is any possibity to find it before? I mean there is any list of jpg in draft?
best regards
Re: Searching small .jpg picture in big draft
Siemens Genius Siemens Genius
Siemens Genius
If you start the Insert Image tool in Drafting the dialog contains a list of the images already inserted in the part.
Does this help?
Siemens Genius
You can also change your selection filter to Drawing Image
And select all or area select to find images - the status line will tell you how many are selected.
If there is a single image in your drawing that can be located using Menu> View >Operation> 'Fit View to selection' after selecting the drawing image as suggested by @JGray.
Ganesh
