Secondary Geometry in Drafting
Hi - ciao,
I want to try this new features in NX11.
I follow the help but I stop when there is to define the Secondary Geometry in the view.
I cannot find the corresponding Secondary Geometry node in the view Setting.
Re: Secondary Geometry in Drafting
Hi @Cesare,
You need to enable Second Geometry in your Drafting Preferences prior to adding your views.  Once the view has been added you can edit it's Second Geometry Settings.
Second Geometry Representations - Frequently Asked Questions
Regards, Ben
