Section View label height factor in NX 9 drafting
Can anyone help how to set section view label (for eg. SECTION A-A) in NX 9.0 drafting with same height factor all the letters.
Example :- I have taken section view in drafting, the label is "SECTION A-A". In this label, letters "SECTION" is smaller in size than the label "A-A". I would like to keep same size for entire label i.e., "SECTION A-A" as one size. Please help how to acheive this in NX9 drafting.
Yunus M
Re: Section View label height factor in NX 9 drafting
Dear all,
I found the solution for this, we can change this as explained below,
Select SECTION A-A label, right click and go to settings, under settings --> Section --> Label. Under Label --> Label --> Prefix add "<C2.0000>SECTION"
Yunus M
More specifically, you would want to change the label to:
<CX.Y>SECTION<C>
Where the "X.Y" matches the current value of "character height factor" for the label. This will make the text "X.Y" times larger than the general note text.
Alternatively, you could change the "character height factor" to 1, this would make the entire view label the same size as the general note text.
Thanks for your reply and sharing the valuable information.
Yunus M
Go to view settings -> Label . There u will find option to change height factor, make it one.
