Section view and hole table
Hi everyone, I was wondering about this thing.
If NX recognize the different hole when i'm doing a dwg using the command "hole table", is there a way to see also in the section view those datas?
For example if I have the holes A1--->A9 , B1-->B3, C1-C2 and I make a section view through A3, B2, C2 I would like to see near the hole in the section view the name of those holes.
Hope to have explained the problem clearly.
Thank you in advice.
