Select connected curves
I've a dwg imported into a drafting view. Now I want to change the color by selecting one curve and automatically all connectec curves. I'm not able. It's possible ?
Thank you...
Using NX11 and NX1847 serie
RuleDesigner PDM
4 REPLIES 4
Re: Select connected curves
Hi Cubalibre,
Not sure if this helps your case but you can use Select Chain while doing the selection
Best Regards
Kapil
Hi @kapilsharma,
the same command is present under selection toolbar, but doesn't work well. Sometime yes and sometime no, maybe the dwg, but I tryed to create relation, but nothing.
Thank you...
RuleDesigner PDM
Hi Cubalibre,
I had a simmilar incident when it didn't work and i this is the reason why selection intent was failing. There was no proper corner intersection available.
Best Regards
Kapil
Hi @kapilsharma,
I don't have this situation. The command fails also with line that are connected via 'Make corner' command.
Thank you...
RuleDesigner PDM
