Selecting entities that are partially in a window.
In I-deas drafting, there was a useful tool that I have not been able to locate in NX drafting.  You could set your selection window to "Part In", which means that an entity that is only partially in the window will be selected, along with the ones completely in the window.  I have attached a file to show an example.
Does anyone know if a similar feature is available in NX drafting?
Thanks.
Re: Selecting entities that are partially in a window.
Menu > Preferences > Selection > Multi-Select: Selection Rule = "Inside/Crossing":
Regards, Ben
Thanks.
