Selection Intent Rules
switching from NX 7.5 to i have noticed a selection problem.  I cant seem to select individual components in my top level assembly. It selects the entire sub-assembly.  Is there a setting i need to change?
Re: Selection Intent Rules
Take a look at the selection toolbar (at the bottom of the ribbon). There are two pull downs on the left, I suspect the 2nd pull down is set to "Within Work Part and Components". Change it to "Entire Assembly" and see if that helps.
Regards, Ben
