Set coordinate dimensions horizontally ?
Hi
How to set coordinate dimension horizontally (or otherwise vertically) ?Horizontally.jpg
4 REPLIES 4
Re: Set coordinate dimensions horizontally ?
This can be done using multiple dimensions option available within Ordinate Dimension command.
Check your dimension settings of the placed dimension or check the drafting preferences what kind of orientation is set for text of the ordinate dimension/annotation.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Ok found.
Difference between these ? (Same results ?)
Horizontal should always give horizontal dimension, no looking to the orientation of the dimension line.
aligned to dimension line is when you wand the text aligned to de dimension line, this is when the dimension line is not vertical or horizontal.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
