Setting for Orient tool
Exist a setting in the customer default or in some place that set the associative check 'on' on orient tool ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Setting for Orient tool
I don't believe so.  I asked a couple versions ago, and there wasn't then, and I have not noticed one since, but it would be a nice addition.  I think I submitted an ER on that, but could be wrong.
-Dave
Hi @DaveK,
if you have an ER, I will use them, if not, I will open an ER. I asked here because I don't want to pass as the only one.
Thank you...
RuleDesigner PDM
Siemens Legend Siemens Legend
Siemens Legend
yes, Customer defaults, drafting standard -View - Workflow - Associative alignment
Or, was this not what you was looking for ?
 ( I am personally not that fond of associative alignment, - i like to turn it off.)
 Tomas
@cubalibre00 I did a search of old ER's, and I don't see one for this, I must have just asked here.
-Dave
Hi @1u7obd,
you don't have understand the question/request. What you talk it's view alignment.
Thank you...
RuleDesigner PDM
@DaveK,
I will open an ER then. Thank you for the support.
Thank you...
RuleDesigner PDM
Share the ER number, and I will request to be added.  Thanks.
-Dave
