Severe error 69
I have a problem with C++ library on some workstation. I enclose the .log file, where error occurs.
Can anyone know, what is going on?
Best regards,
Jack1
Re: Severe error 69
could potentially be a known issue that's fixed in NX11.0.2 and NX12, but you're best option is to send the information to Siemens GTAC to ask for their analysis.
Anthony Galante
Senior Support Engineer
PhoenxPLM
Re: Severe error 69
Hi @Jack1,
@PhoeNX_Support is correct - there were some JT issues that were reported that were fixed in NX 11 and NX 12.  One of which I found was backported to NX 10.0.3 mp16.  Since the error in your log file makes a call to a JT library I'd be inclined to make sure you have the latest maintenance pack for NX10.0.3 installed, which is currently mp19.  If you continue to get the error after installing the mp, report the problem to GTAC and supply your complete syslog along with a sample assembly that demonstrates the problem (if possible).
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
