Shortcut For Window change
Is there any shortcut key for changing the window(one window to another)?.
Solidworks has Ctrl+Tab.....
1 REPLY 1
Re: Shortcut For Window change
It is CTRL+TAB in NX12 and later.  You may be able to create one in NX10 but not sure.  I would suggest upgrading to a current version if you can.
