Shortcut key to make work part the displayed part?
Is there an easy way to make the work part the displayed part? The only ways are through the assembly navigator or right clicking in the graphics interface.
Re: Shortcut key to make work part the displayed part?
Hi @Baratheon
By default, There is no shortcut for make work part or displayed part. There was an enhancement made in NX12 Multiple Display Parts.
Now for NX11, either you can use 'Ctrl+Tab' to toggle between multiple parts in session. Also, You can set user defined keyboard shortcut (Ctrl + 1) in 'Application Only' context for 'Set Work Part' and 'Set Displayed Part'. (Menu > Assemblies > Context Control ).
If you like using the assembly navigator you can select a part and press the [Enter] key on your keyboard. In the scene you can double click. That works in the assembly navigator also.
Eric
