Simulation (Design and Advanced)
For the Design and Advance feautres for Simulation, do I need to purchase a separate license to use these? I keep getting a license server error.nx.PNG
9 REPLIES 9
Re: Simulation (Design and Advanced)
Honored Contributor
Honored Contributor
Or select that bundle, if you already have it.
-Dave
I looked...I have
NX Advanced FEM
NX Mach 3 Ind Design
NX Mach 2 Prod Design
I looked in all of them and see nothing for it. Does this mean I need to purchase another bundle? Do you know what bundle I need?
Select the NX Advanced FEM bundle beforehand.
Larry Carpenter, P.E.
Does any one else use NX at your location? Perhaps one of them is inadvertently using the license, making it unavailable for you.
I'm not a CAE expert, but I think your Advanced FEM license doesn't allow using Design Simulation.
In the applications tab, you could try clicking on Advanced or Pre/Post (depending on the version of NX being used, see image below).
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Bump
Design and Advanced Sim are two different license bundles each requiring their own licensing.
Thank you Larry.
