Sketch Name vs Feature Name
I'm new to NX and not understanding why sketches appear to have 2 names. There's the "Name" and the "Feature Name". Is there a purpose for that ? Every other feature appear to only have a "Feature Name".
Also the Name is always in ALL CAPS. I'm sure there's a clever explanation for this.
Thanks!
Marc
10 REPLIES 10
Re: Sketch Name vs Feature Name
It is the place to name your sketch. Some people assign the name of what the skecth represents.
Scott
Hi @lemarc,
In the 'Part Navigator Properties' dialog, you can set the 'Name Display' option.
Either search for 'Part Navigator Properties' by command finder or right click on white space in part navigator and go to properties.
Ganesh Kadole
@GaneshKadole thanks so much that's acutally a great tip that I didn't know Smiley Happy So now my sketches have only 2 names instead of 3 names!
I'm still baffled at the behavior of the sketches that appear to have 2 names. Any idea how to get rid of the sketch "name" and just keep the "feature name". I like to keep my part navigator super easy to read and this is not helping. I may just have to live with this...
Hi @lemarc,
You can't, and you can't prevent the initial name from being upper case.
Please consider opening an ER with your local GTAC office.
Regards, Ben
Thanks, never knew that this existed
One way that I have found to reduce the clutter is;
In the Part Navigator, right click off one of the column headers eg Name
Select Properties
General Tab
Name Display - I use "User Replaces System"
Now if I have customised any names, I see my naming, otherwise it shows the (one) system name.
Unfortunately this setting is not persist and does not seem to get stored in the Dialog Memory. So this means that it needs to be set for every session of Nx
Keith
in the sketch, upper left window....double click sketch name>cut>type in new name
I believe the field fowlplay" shows is only available if you edit sketches "in task environment" (vs. "Direct edit")
I believe the same thing can be set if you Right-click on the sketch feature in the Part Navigator -> Properties -> General tab, and change the "Name" field
Select Properties
General Tab
Keith
Hi @irvinek
Not true.  To persist this setting go to Customer Defaults->Gateway->Part Navigator->Name Display and set as required.
Dave
