Smash symbol
I've created a custom symbol where curves and texts have color, but when I smash, color begun for all the same. It's normal ?
Thank you...
Using NX1867
RuleDesigner PDM
Re: Smash symbol
@cubalibre00 what are your settings (annotation & Geometry Preferences) when placing/Smashing the symbol?
Default the are on "use current", but when you set this to "use definition" then it will leave the colors as defined in the symbol.
when use de setting "use current" it will take the settings as defined in the drafting preferences.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
