Smooth spline NX10
Dear All
Now I use NX10.0.2.
I would like to use Smooth Spline as NX6. Usually I use segments option and press smooth to adjust spline.
How to enable this option?
Do you have some reccommend for this option?
Thank you.
4 REPLIES 4
Re: Smooth spline NX10
It is there, but for how many more versions?
search for "edit curve" in command finder
"Parameters (legacy)" is what you are looking for
Depending on the spline type selected you get the new or old edit dialog.
It is probably worth looking at the newer curve tools.
You can use X-FORM for smoothing the curve also.
Best Regards
Kapil
Or even better use  FIT SPLINE (under fit curve) to create a more smooth relica of the same (associative and you can validate the deviation also simultaneously)
Best Regards
Kapil
Thank you very much.Smiley Happy
