SolR is not indexing attributes
Hello everyone!
It seems that SolR is not indexing attributes even if I check the setting. It does not respond to keywords contained in the attributes of the library files, only in the filenames. Am I doing something wrong or misunderstanding something?
Re: SolR is not indexing attributes
Hi @Scaffold,
I'm under NX11 and SoIR 3.0.1 and attribute are discovered.
I'm not sure, but I think that the last SoIR it's not compatible with NX10.
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Hello @Scaffold,
Have a look at this newsletters Article, not sure if it will help, but it has some tips an tricks.
https://solutions.industrysoftware.automation.siemens.com/docs/newsletter/Solr-Indexing-for-the-Reus...
Kind regards,
Dennis
Dennis de Brouwer
Application Support Engineer
GTAC EMEA - Siemens Industry Software
Thanks! I will have a look!
