Solution for NX Document Server "Http Error 500, Problem accessing, Server error..."
Solution for NX Document Server "Http Errpr 500,Server error".
Because of NX 10.0 Documentation server use Jetty 8.1 for JSP Http server, and it can only support java 7.0.
So if you has this problem, please uninstall all the java JRE application, and only install the Java 7.0 application.
Then the problem will be resolved.Smiley Happy
Jeff.
Knowledge shared with others are more enjoyed!
