Spring Model
Can anyone teach me on how to simulate a spring deformation?
Just a simple kinematics will do.
Thanks in advance.
Re: Spring Model
Use a deformable Component.  Attached is an example where I've done this.  Open that Assembly and you can edit the 'Height' expression between the values of 11 and 14 inches to see how the springs react.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Re: Spring Model
Hi, thanks for the reply.
do you mean the command in the Menu>Tools>Define deformable components?
I have already done that but it's not a real time simulation, is there another way?
